Enhance your 1/48 Miniart or Tamiya P-47D with this highly detailed, 16K high-resolution 3D-printed replica of the Pratt & Whitney R-2800 Double Wasp engine. Designed for modelers who demand historical accuracy, this engine is available in two key variants:
R-2800-59 – Features the GE Turtleback ignition system for most Bubbletop variants*
R-2800-21 – Features the Bendix Scintilla ignition system for most Razorback variants*
Each version is specifically designed as a drop-fit replacement for its respective kit, allowing for seamless installation inside the cowl or as a fully or partially exposed display option.
Available Variants:
Bubbletop Versions
✔ R-2800-59 for Miniart P-47D Advanced Bubbletop
✔ R-2800-59 for Miniart P-47D Basic Bubbletop
✔ R-2800-59 for Tamiya P-47D Bubbletop
Razorback Versions
✔ R-2800-21 for Miniart P-47D Advanced Razorback
✔ R-2800-21 for Miniart P-47D Basic Razorback
✔ R-2800-21 for Tamiya P-47D Razorback
Key Features of This Model:
✔ High-resolution 16K 3D print using premium materials for exceptional detail.
✔ One-piece design (except for the prop shaft) for easy assembly
✔ Drop-fit compatibility with respective Miniart & Tamiya kits.
✔ Designed for seamless installation—fits directly into the cowl or can be displayed with full or partial cowl removal.
✔ Tamiya versions are compatible with the kit polycap and Part B25, allowing for a rotating prop.
For further details go over to the Matter of Scale product detail page.
Matters of Scale also have several other radial engines including a full set of detailed engines for the Hong Kong/Eduard B-17 in 1/48.
All matter of Scale products are made by me in the USA and shipped worldwide. Check out Matter of Scale website.
